Well the Dodge dealer pulled a fast one on me. I bought a '06 3500 Megacab SRW, and cant use it to tow our trailer now, according to GVWR. I should have gone and weighed the truck myself before I bought it, I know now. Next time I will do more homework than just calculating based on listed specs.
Truck: GVWR = 9900lbs
GAWR front = 5500lbs
GAWR rear = 6600lbs
Dodge listed payload capacity = 2590lbs
actual curb weight = 7880lbs per CAT scale
actual payload capacity = 2020lbs
Trailer: GVWR 13000lbs
actual loaded wt. = 11800lbs
actual tongue wt. = 2340lbs.
Sliding hitch wt. = approx. 350lbs
extra person + dogs + whatever = approx 400lbs
Question is since the GCWR = 23000 and the GAWR = 6600lbs are both within capacity, is the fact that the GVWR of 9900lbs is exceeded mean anything? The trailer has its own brakes, none of the tires will be over capacity if I run them at max pressure, and Dodge says you can tow more trailer than I have in the specs - do I have a problem or not?
Question II: Does the 9900lbs GVWR apply when the weight is tongue wt? According to Dodge it should never be exceeded. So how do they list a towable weight of 15,850lbs? I dont care about the warranty end anyway - as I do most all repair and maintenance work on my trucks anyway.
GAWR rear = 6600lbs
