I have tried several times by responding to other threads where members have stated they had no EGT problems towing 8k# - 12K# in the mountains with Stage 1 or 2 injectors, and a box.
"How fast were you going at these "Safe" EGT temps, and at what altitude?"... no answer.
I live in Colorado, and I don't consider a 4% grade for 2 miles and 3k feet a mountain. I am trying to decide the best (and cheapest) injector/box combination for doing 7 - 8% grades for 10 miles at a peak altitude of 11k feet towing a 10k# fifth wheel. If I am going less than 60mph on a straight run, there is a problem, and the setup needs to be changed.
Right now I have a 2002 3500 ETH/DEE, and will be putting the Edge EZ and AFE back on after I settle this pesky VP problem (0216). Other than the Ex-brake and the missing muffler, the truck is stock. Gauges are next, then injectors and clutch. If at all possible, I want to avoid having to go bigger on the turbo.
Lets hear what you have (box, injector, ETH or ETC,... ) and how fast you were going on high altitude passes (8000+ feet) towing your second home.
Thanks in advance!
Thanks in advance!
