I was towing a 3000lbs load this week. Drove about 1000mi between 1000 ft elevation and 3500 ft elevation. I would keep it locked out of overdrive when I was driving 60mph or under. My RPM's were around 2500 and EGT's were fine. When I was on the Interstate I would keep it in o/d in order to make time. My cruising speeds were 75mph to 80mph and my egt's were between 300 and 900 depending on elevation and incline. The only time I would take it out of o/d on the interstate was on extreme upgrades that took my EGT's over 900.
My question is: am I damaging my transmission towing in o/d with a moderately light load (3000lbs)? And is 900 degrees too hot to run for extended periods of time?
