Is there a problem with towing my 6000 pound trailer in overdrive if im towing at freeway speeds (60 + mph). Thanks.
Originally posted by Howard Durand
I tow in OD as much as possible.
As long as the TC is locked up, and you can maintain adequate engine rpm, there should be no problems. .
With the 3. 54 gears, I have to keep the speed around 60 to maintain good engine rpm.
I very seldom see 2200 rpm unless climbing a hill. Then it is out of OD.
I have asked that question several times and I will tell you what I THINK is the truth. The reason the transmission works is oil pressure. At speeds below 1750 or so the oil pump is not at rpms to develop maximum oil pressure with the 3. 8 gallons per min. The newer transmission has I think 4. 2 gallons per min. If you transmission is in good shape and doesn't have a lot of leakage that may help also. I would not use a stock transmission at below 1750 rpms when towing. I manual shift, starting in d2 letting the truck shift from first to second, next use the lock out button and manual shift using rpms to land me at 1750 in 3 gear. I always let off the throttle and ease into the throttle. Next I use rpms just like the other gears to land me at the desired rpms at 4 gear. I do this every time I tow heavy. . Now I have been told that manual shifting may not be the best for my transmission but I have 99k miles and besides a TPS switch, no problems.Originally posted by firemanshawn
That is a very good transmission. I have a # 6 plate slid all the way forward along with 17. 5 degrees timing. To each his on. Good luck. jimOriginally posted by bramage
My first CTD was a stock 96 auto. I sold it with almost 190,000 miles (75-80 percent towing a enclosed 8000lb work trailer) and it now has over 250,000 miles on the original transmission. (I sold it to a neighbor) It is still going strong and I never once pushed the button to turn O/D off. Now my '97 auto with a #6 plate is a totally different story. If it is stock I don't think you will hurt it with your boat. Just my . 02.
Jr
