Towing Mirror broke - Can I lube?
Body Lifts?
Waxoyl?
Well, I flipped up the passenger side mirror on the weekend and tried to adjust it... the mirror broke! :mad:
I also noticed that both mirrors are very difficult to adjust... they just seem too hard to move... . as evidenced by me breaking one. Is there a way to lube whatever pivotpoint is inside the mirror?
while adjusting mine the mirror fell into my hand. the mirror was very hard to adjust. while the mirror was out i removed the star (lock nut washer) and separated the three pieces. i filed the white center cone tabs a tiny bit. use a small amount of wheel bearing grease and reassembled. i pounded the star back into its normal position,used a long 3/8 socket that fit over the plastic stud the nut went on. pound the star on and adjust the mirror,,,still loose pound it on a little more. i reattached the mirror with epoxy. ken
