My Dodge is a 2002 HO, 3:54 Rearend with a 6 speed manual. I currently tow a 10K trailer. When driving the speed limit in California (55) my RPM in 6th. is just under 1600 (the lower range of peak torque). In 5th. the RPM's jump to around 2200-2300. The latter certainly within the peak torque range of 505 ft. lbs.
While I don't have a sense that driving in OD is a problem with the Cummins, I am curious if there maybe some driveline issues I maybe facing in light of my lower RPM's? The difference in mileage using OD vs 5th. is approximately a Plus 2 mpg. However the fuel savings is not worth it should I be inadvertenly be damaging my drivetrain at the lower RPM's.
Any insight is appreciated.
Charlie
Charlie
