Who has a #10 plate a set of higher horse power injectors and towing a travel trailer or 5th Wheel and other loads? Where do you have the fuel plate set? Do you have the AFC set full forward and no spring tension or do you have some smoke control? I have the #10 plate set forward of center a set of DDP stage 2 inj. and the AFC back alittle from full forward and the 215hp spring adjusted a from full loose for smoke control. I just got back from towing the our 5ht wheel to see what the egt's would be. Trying to get up to the speed limit of 70mph the et's would climd to 1200 degrees pretty easy, once the speed was reached towing temps was 100o drop to 65mph temps would drop to 850. Does this seem normal. Should I set the #10 plate in the center, try to find a #11 plate or put the stock plate in and set it forward? I know I am in need of a better breathing turbo to help keep the egt's down. Do I need to back the plate some? Would like to here what you have done.
TIA<!-- google_ad_section_end --><!-- google_ad_section_end --><!-- / message --><!-- sig -->
