Towing with a HTT/64/13SS
Install On A Killswitch
Ok for you guys running the HTT/64/13SS on your 04. 5 and up trucks that tow, do you have any surging? I am mainly interested in the automatic trucks but all input is nice. Also what weight trailer do you tow and HP level is your truck?
Thanks,
Doug
I went from a 64/65/12 to a 64/65/13ss and 4 days later sent that back for the 64/71/14 cast. The ss was of no benefit over the B2 except it was about 150-200 degrees HOTTER across the board. As far as surging the B2 was a pig and the ss wasn't any better for the short time it was on. I can tell you that the 71series is way smoother and 150-200 degrees cooler across the board than the B2. Surge wise if I run w/o any timing it doesnt surge at all. The lag is only marginal over the B2.
