I am not sure you can say that a pressure box is the definate source of a leak or even cracked injectors. Did your friend get it fixed? Has it leaked again? I know it is easy to look at an aftermarket part immediately if something breaks, but there are quite a few bone stock trucks that have the same exact failures. How do you explain them? I really wished the Big 3 would get a handle on the injectors, but I think it is something we are just going to have to live with. I have spoke to several engineers and they seem to think that poor fuel quality attributes to a lot of injector failures. They say it could be the fuel, how it is stored etc. They also said people with regular fuel filter changes seem to have way less problems. Even if it is not completely dead they recommend changing the filter about every 2 oil changes 6-7K miles or so.
Usually what happens is that if you have a part that is failing or not operating 100% the aftermarket part can certainly help it fail. Some people do not like pressure and some people do there are big upsides and some downsides if it is not done properly.
Duration and timing works good, but duration gets really hot if you do not have the turbo and other mods to go with it.
For those that do not like pressure you are certainly going to be upset when they switch to the Bosch 2 system which operates in the 29K-30K range! Our 06 LBZ duramax uses a lot of pressure from the factory!
Just food for thought?
