Toy Hauler For a Jeep
102" wide 5er, factory tow mirrors...
how much air psi in air bags?
Doesd anyone know of a company that builds a toy hauler trailer that can support a Jeep inside? I can only seem to find units that can carry ATV's.
Yeah, I tried to find the same thing and could not find anything that would support the weight and length of my TJ Unlimited, so I got a 3814SS Raptor and can flat tow my Jeep behind the trailer. That way I can still bring my quads along. The problem with the other trailers is there living quarters are a little cramped (wifes toy too). So I had to compromise. Jeep are pretty heavy and to get a real toy hauler with all the "stuff" they are usually too low on the actual cargo capacity. Plus, if you don't get a partition, you will smell gas and oil in your living quarters, which takes awhile to vent out. Scotty
Do you have a pic of that all setup and ready to tow?
I do at home, I am currently away from the house, but once I get home I will be happy to send you one. It is long, but it pulls really well. I couldn't be happier with the set up and I don't have to worry about overloading my trailer with cargo. Scotty
Added some pics, minus the Jeep
A dealership here in Montana sells a trailer called the Work & Play I believe it can haul that much weight. Give them a call 406-761-3520
I have a trailer for sale that will hold your jeep. How big is your jeep? Do you have wider axles?
21. 4" on the floor + vee nose. bumper pull
2 8,000 lb axle 8 lug (8 on 6. 5)
4 bunks that fold up against wall
3 way fridge (propane, ac, dc)
microwave
20,000 btu furnace
16,000 btu rough neck AC unit
40,000 btu Bosh on demand water heater, never run out of hot water. flotec variable rpm constant pressure pump.
4000 watt onan micro quite generator
40 gal fuel tank with transfer pump and filter (the generator uses this fuel so it has to be some grade of unleaded fuel in the tank)
weber grill
2 inch insulation in roof
1 inch in walls
the entire inside is sprayed with armorthane spray in polyurathane bedliner. clean up is as easy as pressure washing and a little soap.
the back gate is lowered by warn 1700lb winch (the winch overkill big time)
Interior lighting includes white leds for battery power and 3 8ft pairs of florescent.
rear flood light
$12,500
I will get some pics if interested.
The Work & Play is built by Forest River; I've seen them but never owned or used one. Toy Hauler Travel Trailers and Fifth Wheels by Forest River
I did camp next to a fellow last year who had a 3-axle toyhauler in which he hauled a Jeep Wrangler. He said that he had it custom-built with a larger-than-normal cargo area (and condensed the living area). He hauled it with a 1-ton Dodge Ram CTD. Unfortunately, I can't recall the manufacturer at the moment.
