TPMS intermittent warning
What charging voltage does your Ram run at
2016 Hesitation when cold, cracked DPF, DEF not ticking
Put new shoes on the truck... picked up an intermittent TPS warning, left front, replaced and picked up a left rear warning... replaced that one and it went away for a week... came back once tonight...
I understand the battery in these sensors fade after about 10 years... if I replace both right side sensors is there something else I need to do within that system? I scanned the sensors and only the front left showed low battery...
Most of the time when a TPMS problem shows up shortly after installing (or removing tire for any other reason) new tires it is because the sensor was damaged during the service. But since your sensors have 9 year old batteries it might be wise to just replace all four.
Going to do just that....Same Size tires as before....thanks for the response
