Tpms
Intake tube crease, from the factory?
Coming up on the first oil change
I want to lower the tire pressure in my rear tires, 2017 2500 Longhorn to improve to ride, at least some. Can the TPMS be reset to a lower pressure to keep the warning light off.
Yes..WITECH or AUTEL... Thiers some threads on this at CF.. lengthy discussions on how to rent and use the AUTEL. WITECH works the best. GA a ways form MN otherwise I do it. Takes about 30-40 Minutes.
Yes it can. Doing so is a 2-step process and the Autel can do both steps, BCM change and RFH reset. The Witech can only do step 2, resetting the RFH. There are other devices that will change the BCM settings.
I've helped more than 140 guys so far all across the U.S. Let me know if you're interested in renting an Autel to do it yourself. Complete instructions included and super easy to do.
