Sometimes on partial grades or under load, the OD kicks in and out. . especially if the throttle is held at a steady spot. If I throttle up, it will shift back into OD. This is an intermittent problem, the dealer last year told me the TPS was acting up and that it cost over 300$ to fix it. Is this something that can be easily repaired/replaced by a reasonably competent shade tree mechanic (me) or is that best left to a pro. Is there an adjustment for this? The Chilton repair manual I have doesn't mention anything about the TPS.
