TPS Question
PODs installed
Tires and Rims
I took my TPS off today that is bad and I took a couple pics of it. Is it suppose to come apart like this? If so where is the other part that you can take apart that everyone talks about? Thanks, Bill
<img src=http://216. 167. 44. 209/programfiles/talers/TPS. JPG>
<img src=http://216. 167. 44. 209/programfiles/talers/TPS2. JPG>
That's it
That's all there is too the TPS setup. If you look at the top of the TPS, it has a groove around the top. I've never actually done this myself, and Bob was the first person to mention it to me, but you can take a dremel and cut the top off and clean the insides and epoxy the top back on. Hope this helps...
Dustin
Just take it apart and clean it . There is nothing to it . Just be careful when you are putting it back together and put it back together dry(advise by Bill Kondalay on the dry part) . I did not glue mine back together though , I cut out a thin piece of stainless steal plate the same diameter as the top of the TPS and drill holes in it so I could bolt it on top of the TPS and made a gasket and put it between the TPS and the plate that way the next time I need to clean it I won't have to cut it apart .
Wayno- great idea!
Jay
