In the 5 years and 117,000 miles that I've had the truck, it has always locked up the TC at 43 mph. This is too low (1,100 rpm) and the truck shakes because it's being lugged. I tried a reflash and that had no affect on the lock up point.
I did a search and read several posts on the TPS but I havent seen this as a symptom. I spoke with Piers yesterday and he suggested the TPS. I tried to adjust it to get the voltage correct (it . 3 @ idle & 2. 0 @ WOT) but about the time I get the voltage to come close the linkage rod came out of the ends. I did consider rotating the switch 90 degrees but then the voltage is way too high and the linkage can't adjust that far.
Other than this, everything seems fine. The voltage transition is smooth as I open the throttle with the voltmeter attached, just low. Does this sound like the TPS? I hate to spend the money for nothing like I did with the reflash.
