Engine/Transmission (1998.5 - 2002) TPS reset again and again and again
Engine/Transmission (1998.5 - 2002) In tank lift pump?!?!?! HELP!
I have been having to reset my TPS (throttle position sensor) with the turn the key 3 times and reset with the accelerator trick over and over lately.
I did get an 0237 and 0234 code this morning.
Can anyone enlighten me on if there is a repair or cleaning that can be done
to fix, or do I need to buy a new TPS sensor?
If so, are they a dealer only item or where can I get and how much.
Thanks.
Eric
To reset the APPS you disconnect the batteries for 30 minutes or longer and then turn on the key and slow depress the pedal, shutoff the key and restart. If you have been doing this and still have problems with TC locking and unlocking, call DTT and get their filter. SNOKING
P0237 = MAP sensor voltage too low.
P0234 = Turbo boost limit exceeded.
Nothing to do with the TPS... .
Marco
