tps switch
Shut Off
Some Balwin Filters
My truck won't shift into overdrive unless i let up on the go pedal and make it shift and then after shifting into overdrive just a little pressure on the pedal and its back into third gear. Do i need to set the voltage at idle on the tps lower or higher to correct the shift?
Lower voltage makes it shift sooner. I set Mom's to about . 65V at idle (key on, engine off). You have to punch it to get it to drop out of OD, which is not entirely bad. Each one will react differently, as well as tastes between drivers will vary.
Daniel
