Engine/Transmission (1998.5 - 2002) Tps Testing
Engine/Transmission (1994 - 1998) coolant water ratio
APPS sensor used 6 wires, three for the actual pedal position and 3 for idle validation switches.
For the pedal position: (Test with key on)
DB/WT is the 5V supply for the sensor
Should be 5V
BK/YL is the sensor ground
Should be very low voltage drop, put black meter lead on batt negative and red meter lead on sensor ground.
LB/BK is the sensor return and will votlage will vary with pedal
Mine is (using a scan tool)
idle = . 42V
WOT = 3. 61v
At . 52V the DRB read 1% open and at 3. 40 was 100%. Your truck may have slightly different values as it should be based on what your minimum APPS voltage is. If I remember right, it's typically 3V above min V for 100%. (Which is real close on my truck).
HTH
Wayne
