Engine/Transmission (1994 - 1998) TPS what shifts does it control?
Engine/Transmission (1998.5 - 2002) '02 fuel line
2nd Gen Non-Engine/Transmission busted fuel line
My transmission feels fine and does not slip, but I do beleive that during normal throttle accelerations, it upshift too fast. Also it like to go into OD lockup as well too soon. I know the TPS deals with TC lockup but how about 1-2-3 shifts? Does overdrive use the TPS reading as well?
How can my shift points be adjusted other than a valve body mod?
The manual says vehicle speed sensor is part of the speedometer pinion gear adapter located on the extension housing of the transmission (TAIL). I had 2-3 shift problems and replaced output sensor on tail of transmission with updated sensor worked fine after that. Manual says erratic-harsh shifts can be caused by plug transmission filter,high-low fluid.
