Engine/Transmission (1994 - 1998) TPS yup it can happen to you
Engine/Transmission (1994 - 1998) P7100 oil level???
Engine/Transmission (1998.5 - 2002) 97,000 To many miles?
First the dealer did a lot of diagnostics and cam up BUBCUS!
the TDR strings have good info on the fix. Thanks guys!
No more erratic shift at 1750-1800 RPM Can use the cruies control again.
KDP next. That I will need help with.
Let you kow how it turns out after first of December
Chuck
Anybody know of a good installer in Northern Virginia that will do an "a" pillar triple mount of ISSPRO guages.
And
Does a 4" or 5" exhaust really make that much difference?
Cheers
CHuck
A little wd-40 then
Sprayed about 1/4 can of CRC contact cleaner into it.
Now rock solid.
Now while installing new shocks (Took 4+hours. ) Has anyone else had trouble with the front shocks on the 95?????
MAN WHAT A PAIN.
Bad news now is I found a gaping hole in my exhaust. Looks like a new 4 or 5 inch exhaust.
Anyone got an opinion on which way to go.
ALso is the stainless steel worth the extra hundred or so bucks?
chEERS
cHUCK
