Details here: TDR Privileges
On a 2005 it should be on the pedal inside the cab. You are most likely looking for the pin that is 2nd from the front of the plug, or second going away from the drivers seat. Once you see it you will know what I am talking about.
There are some 2004. 5 trucks that the TPS is located under the drivers side battery. If this is the one you need then look for pin#5. It should be Brown with a white stripe.
