Engine/Transmission (1998.5 - 2002) Tps
Engine/Transmission (1994 - 1998) Gainesville/Ocala KDP
I assume you mean the Throttle Position Sensor (Commonly called APPS (Accelerator Pedal Position Sensor)
It is located on the drivers side, front top corner of the cylinder head, right above the injector pump, underneath the black curved plastic housing. If you follow the throttle cable to the end, you will find it!
Same place as the 98. 5, 2000, 2001 & 2002
Here is a link to a search for APPS/TPS. There is alot of good info.
Take a look at this page for a drawing of the engine.
I would highly reccomend getting a service manual, its the best $100 you will spend on your truck.
