Tps/Kick down cable adjustment
First off I'll explain my problem. no lockup of TC in 3rd gear and at about 70-75 if you push the pedal down to pass someone the TC unlocks and then locks back up after acouple fo seconds.
Second, the fixes I have tried. I've cleaned the connections with contact cleaner. I'm going to go out and use my volt meter to test the voltages of the TPS.
I read up on the noise filter on the DTT site. It says with problems between 40-60. I haven't had the problem in that range just at about 70-75.
TIA
Nathan
TIA
Nathan
