Track bar compat with F. Mag hytec
Would You Recommend These Rims???
DTT Power Puller Upgrade
Which aftermarket trackbar will work with the mag hytec cover? I have heard that some have clearance problems. Does DT work?
So Blair, are you saying I could use it with the 4. 5" lift ? man that just seems a little close 1/2" clearence. Have you seen or does anybody have a picture of one installed on a rig with the skyjacker 4. 5" lift ? If it will clear I would like to add one when I do a locker up front.
BBD
Guys, I can painfully say from personal first hand experience, none of the aftermarket front diff covers will work with the DT track bar unless you have 4 1/2" of front end lift or more, as Blair pointed out.
I *think* the OEM track bar should work just fine with 2" of front end lift or more.
Scott, Mr. Sutton has the DT bar, 4 1/2" Skyjacker system and the MagView front pumpkin cover.
I think Phil "rubberneck" responded to a similar thread several months back and said he got a DT track bar to work with a 2 1/2" lift kit and one of the aftermarket front diff covers..... darned if I can imagine how though... ...
Tom
TTT.
I am looking into this, and have the same original question. What ones work witht the mag-hytec front diff cover. It seems the DT one proably wont, but how about the others.
Moog, TRW, and so on?
I'm using a NAPA track bar on my '97, no clearance problem at all. Just returned from an elk hunt on gnarly trails so I fully used the suspension travel, no rubbing on the knuckle of the bar or on the cover or its bolts.
I have a moog replacement bar and D-25 coils inf front, clears the Mag hytec fine. Even when I had a Lukes on my track bar it never contacted the pumpkin. I guess the 2. 5 lift helps.
