2nd Gen Non-Engine/Transmission Track bar removal
Engine/Transmission (1998.5 - 2002) Chrysler Canada website?
Engine/Transmission (1994 - 1998) 8.3 Turbo Exhaust Housing
I tried over over two hours yesterday to remove the P. O. S. track bar. I tried the pickle fork. All I managed to do was bend the hell out of it. I tried using a hammer from the top. The thing just won't budge. The pickle fork I used is a ball joint separator. It has a 15/16 opening. Is this right? What other methods are you guys using? I searched all of the forums and nobody seemed to have any problems removing it. I am trying to install the lukes link.
Any help is appreciated
Thanks
Curt
I had a similar experience - wrenched every muscle hammering on it and broke the pickle fork. I purchased a hardened steel fork made for an air chisel and spent a $100 on a Chicago Pneumatic air chisel/hammer.
I let that go at it for a few minutes, then tapped a couple of times on the end of the fork and POP, out it came.
Was worth every cent of the investment.
Good luck!
Thanks for the replys. We are having a bombing day in a couple of weeks. Hopefully they will have some tools that will work. I think I can rent a pittman arm pulling from auto zone.
So much for the 1/2 hour job. I totally destroyed the rubber boot around the link. Is it all right to run it this way for two weeks?
Thanks again for your help.
Curt
