SSI Trackbar
I replaced two trackbars before I tried others. . Lukes Link hit my diff cover, so I pulled it. I finally went with the Solid Steel industries adjustable track bar and bracket (The adjustable track bar is a must if you have, or plan to, lift the truck)... They also make a solid replacement bar... A shop I dealt with welded the bracket; as they felt it was moving... A good combo... several shops, including KORE, make adjustable trackbars, but you will have to source a bracket?... I would suggesting checking with KORE or Desert Racing Concepts to see what they have... replacing the dodge bar with a lifetime guarantee product (Napa used to have one) is another option... but then you still have to change it out every 20-30k. my experience fwiw.
