Trackbar bushing install mistake?
2006 tach issues!!! HELP!!
04.5 3500 Ram Quad Cab Headlight Adjustment
Quick question, I put new Luke links bushings in the truck, but I used grease. Should I pull them off and put synthetic brake grease on instead?
TIA.
I assume you used the poly bushing... in most cases on a class 8 truck, poly bushing are used in locations where no lubrication is applied through the life of the bushing...
These bushing are used on steering links, sway bar links on most of the air bag suspensions and are out in the water from the roads where the water would wash off any lubrication in a matter of days...
Thanks for the help!!
I think my other bushings must really been worn out. The steering is tight, and the shocks feel like their working more(if that makes sence).
So hows the Luke links doing?? I have a 2004 and was going to replace other bushings with the Maxx links. . Am thinking of replacing the tie rod bushings and trackbar/etc. .
