I have two trucks now, and both sport traction bars. I think anytime you add something to the rear of the truck in hopes of controlling it's behavior, you are going to give up some things in that area. it's a compromise, you ask the traction bars to keep the rear springs from wrapping up in certain situations like take offs and during backing. They also help in other areas like control over bumps, but yes they will cause some bind in certain spots. The key is to minimize that compromise, and get enough positive response to off-set the negative.
My Ford truck runs a set of FabriTech traction bars, they are a nice set and not that expensive. I Had a bad time whenever I went over several bumps in a row, especially in a corner. The rear would dance around and the result was bad ride and loss of control. The bars fixed that, they also fix the problem of the springs wrapping up when backing. I have large tires on it and for , the bars where necessary. On the Dodge, I didn't have such a sever need for them, It never steeped out in the corners like the Ford, but I did like the way it helps with control. I also have to back a very large and heavy trailer, and they make it much more enjoyable.
There are at least 4-5 sources for traction bars to fit your Dodge. FabriTech has two, Tuff Country has a set, Rancho and FabTech both have a set, though they might not be listed as for your model. Pro Comp and a few others offer traction bars for the Dodge as well. I wouldn't get to caught up on any of them, basically they will all do the same thing, you are not in competition or scorching the desert in the Baja 1000. On mine I used the Rancho line, they did not offer one for the Dodge but I made the rear mount and they worked fine. I had used them in the past, and liked the simple, but strong and clean look. Good luck and post your results.
