Traction problems
Dually Air Pressure
Espar revisited
I can't even get close to getting my truck to "hook up" with the Comp on anything above 2. What is the secret. Guess I need a posi rear or something. This is ridiculous. Had the comp on 5x5 and rolled into the throttle, once boost came up I mashed the throttle at about 35 and the tire/s went up in smoke. :{ I know there is a cheap solution to this. How in the world do you guys with real power drive your trucks :confused: At least I can dial the power down, if I install a turbo and injectors will it even be drivable?
Should be able to find some stickier tires or maybe even put more weight in the bed... just like in the winter for driving in the snow
Slip it into 4 hi. Ihave smoked my tires through the traps with 35" tires, in 4wd that problem goes away :D
Bob
