TRACTOR PULL IN RIPON CA 3-14-01 DIRECTIONS
Florida Happenings
2nd Central Fla Meeting
Okay here's the scoop the pull is in Ripon Ca at 2:00 Pm Saturday the 17th of march. Directions are as follows, HWY 99 north or south depending on your location to JACK TONE RD off ramp, go West to CANAL BLVD, turn Left on Canal continue it will curve to the right continue straight there will be a vacant lot on your right that is the place. (209)652-5303 or (209)613-9675 these are my phone numbers in case anyone gets lost, the pull will end about 5:30 or 6:00 followed by a distruction derby until 10:00 Pm, anyone who wants to pull will be able to as long as you get signed in first, I recommend getting there early if you want to pull it can be kind of a zoo at times. Hopeto see a strong showing from the Dodge boy there may be a few Fords around in need of an attitude adjustment. WIZ1
2001. 5 ETH/DEE 4x4, DRW QC DD3's, EZ, HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,relocated blow by bottle,Lucerix power heated mirrors,more to come
