The Carrier
I beleive the 89's used the 60 series axle housing where the 2nd gen uses the 70 so you may have to research it more. The above post explains it clearly on the ring and pinion changes that can be made by using the same "carrier", that is the assy that holds the ring gear, but if you do not have limited slip it may be a diff carrier, again check with gear dealers on this. I would think with a hi performance application as you have the hi speed ratios. . 3:55 down to 3:07 might be ok for light hauling. Call Joint Clutch and Gear, 989-686-2924, Bay City, Michigan. They helped me with the necessary info. Also it is a "must have" to provide the axle housing ID numbers that are either stamped in the housing or on a tag bolted to the axle inspection housing cover. Having this number gets instant parts help. TL
