Trailer Brakes, beware!!!
test your towing knowledge here
New 5th wheel camper - heated storage tanks?
I went to adjust my brakes on my 1996 TravelEZE 35ft 5th wheel with Dexter axles.
The reason I wanted to adjust my brakes was they were not working so well on my last trip.
Each time before leaving on a trip I test the trailer brakes by moving about 5 MPH, then I use only the electric brakes and normally they stop me just fine. But not this last time! The truck just kept on rolling along. I could feel some brakes being applied but not enough to stop 22K pounds.
What I found was most scary!
The first thing I did was jacked up one wheel to do the adjustment.
When I stuck the Spoon in to adjust the brakes, the adjuster was gone.
I took the wheel off, then the hub and all the adjuster parts were just laying in the bottom of the hub and fell out.
The return springs had broken (on all 4 wheels) and allowed the adjusters to fall off of all 4 wheels.
You can imagine the damage to all those loss parts and the shoes and other internal parts as the wheel just went on rolling as we went down the road.
Please, Please check your brakes, and service them or have them serviced reguarly.
Safety is Number 1
Bob
1998. 5, 2500, SLT, Red over Driftwood, 24V, 4X4, Auto, 4. 10, Light Group, Camper Special group, Convenience Group, Travel Group, Trailer Group, Keyless entry, 5 band EQ and 6 disk changer. (ruck is 4-Sale) towing a 35ft. Travel EZE 5er.
It in, due to pick up May 9 or 10, a 2001 3500, SLT+, Green, Tan leather, Duel Power Seats, HO, 6 speed, 4X4, 4. 10, Towing Package, Trailer Tow Mirrors, Camper Package, Sliding rear Window, Jacob’s E-brakes (Dodge), Electric Steps (Dodge), Mud Flaps on all 4s (Dodge). It has every option offered by dodge except the snowplow, including the front Air Dam. Line-X over the rail bed liner, 20K Reese 5th wheel Hitch with Gooseneck, 30” toolbox.
If yours needs it I've found it cheaper to replace my Dexter drums with new ones than to get them turned.
'95 2500 4X4, AT, Driftwood, Banks Stinger, Warn fender flairs and running boards (work truck)
'95 3500, 5 speed, 3:54, BD E-brake, Driftwood, Banks & Psycotty, 34,000 GCW apple and tractor hauler (works harder truck)
Sounds like the same failure as my parents '97 Carriage w/Dexter Axles. I believe Dexter admitted to having a bad batch of return springs and they paid for ALL the work to repair the trailer.
I don't know the particulars of who my dad spoke with at Dexter but I can find out if you'd like.
Email me for the info.
Brian
I have contacted Dexter, we will see what there responce is!
Thanks
Bob
BROBESON:: I see you have a 96 MY trailer. How many miles on it? Have you inspected the brakes before this happened? I
think I will ck. mine this week.
I had the same problem with my Jacobsen flatbed trailer. I was lucky and caught it before there was very much damage. I went to a trailer place and got heavier springs and haven't had a problem since, that was about 3 years ago.
Rodney
I have had the trailer for 4 years, bought it used, they said they only used it once or twice.
We have put about 10K miles on it. The trailer is in perfect condition. Even the tires show no signs of wear.
I never took apart the hubs before, but I all ways do a brake test before each trip or anytime I am stopped.
The brakes worked before leaveing for San Fransico, they did not work when I left San Fransico for my trip home. I have no way of knowing if the springs all died at the same time, or if one at a time or what.
Once home is when I found the problem.
Bob
I just received an E-mail from the Dexter Alex company.
They said they know they had some problems with the return springs in 1996 and 1997 and will replace all damaged parts.
Way to go Dexter, we need more companies like that.
Bob
1998. 5, 2500, SLT, Red over Driftwood, 24V, 4X4, Auto, 4. 10, Light Group, Camper Special group, Convenience Group, Travel Group, Trailer Group, Keyless entry, 5 band EQ and 6 disk changer. (truck is 4-Sale) towing a 35ft. Travel EZE 5er.
It's in, due to pick up May 10 or 11, a factory ordered 2001 3500, SLT+, Green, Tan leather, Duel Power Seats, HO, 6 speed, 4X6, 4. 10, Towing Package, Trailer Tow Mirrors, Camper Package, Sliding rear Window, Jacob’s E-brakes (Dodge), Electric Steps (Dodge), Mud Flaps on all 4s (Dodge) Line-X over the rail bed liner, 20K Reese 5th wheel Hitch with Gooseneck, 30” toolbox and tailgate box.
BEWARE!!!!! I just found the same problem
TTT Went to adjust the brakes on my 1997 Mallard 5er and jguess what no star wheel!!!!!!!!!! :mad: :mad:
You guys better check them out :eek:
I remembered this post and just bought my new 3 ton jack so I
went out to adjust the brakes and bamo loose parts in the drum:mad:
I've only checked one wheel so far I will report back.
<font color=red>CHECK THOSE BRAKES BEFORE LEAVING HOME </FONT>
<b>EDIT Checked 3 gone :mad: Bob I sent you an email :)</b>
If you have a 1996 - 1997 get under there
