Thanks in advance.
We are replacing the floor in our troop's Boy Scout enclosed trailer. Today we ripped out the old floor. Last fall a tire blew and it blew a hole in the floor. It had 1/4" wafer(?) board over 3/4" plywood. We are thinking of replacing it with pressure treated 3/4" plywood with 1/4" plywood over that. (Shelving, etc. was sized for this floor thickness and the 1/4" plywood should keep the chemicals in the pressure treated plywood away from all the gear and food. )
Are we on the right track?
Is there a better way to do this (remember this is a scout troop and we need to keep expenses down).
Should we coat the bottom (exposed) side? If so, what would you suggest?
Any other ideas?
Thanks for all the help.
Gene
Any other ideas?
Gene
