Trailer Life article ATS performance up grades
Take A Peek At What We Are Working On
4bt counter balancer
lorirobert
I would like to up grade my 2004. 5 3500 and the article in the new trailer life magazine i found to be informative because it showed the before and after results of the up grade and also the real world road test. My truck is used as a daily driver and pulls our vacation home, a 32ft. Sunny Brook 5th. wheel. any input would be appreciated as i dont want to go about it blindly . Thanks Robert
Robert,
If I were you I would research everything. I dont trust magazines (Im not saying that was a bad article, I didnt read it). If you use the search feature on here, there is a wealth of knowledge. More than you would probably ever want to know.
you will find that the most expensive is not always the best. Some of the people on here are biased towards certain products, and against others. Some for good reason, others for not so good reasons. Spend some time reading on here, and Im sure you will find what you want.
--Jeff
