I think the ground problem is not as prevelant as it used to be. Now, they have a ground in the trailer plug but that was not always the case. You had to rely on a mechanical connection in the hitch for your ground. That was a really bad idea.
I do believe however, that grounds are usually overlooked as the cause in electrical issues. Most people forget that they are also part of the circuit. That's why, when I bought my CTD, I also installed extra grounds. I started by buying 2/0 welding wire and heavy duty copper lugs at the welding supply. I made up extra grounds to go from each battery to a central point on the head and from there down to the frame. I also made up an extra ground that goes from the battery to the body. All the connections are first wire brushed to be sure they are clean and then dielectric grease is applied along with stainless star washers to prevent corosion and insure a good mechanical connection to ground. Finally, all the wires were covered with split loom to appear factory. This will go a long way to solving any future ground failures.
-Paul R. Haller-
