Archived Trailer Lights Fuse?
Archived Truck dead after injector pump install
Archived crank sensor part #......
Does anyone know which fuse the Trailer Lights Outlet is hooked into? I don't have my Owners Manual.
I would like to hook up my trailer before this snowstorm hits.
One other thing, is there more than one fuse box? I know of the one under the hood, but is there one in the cab as well?
Any and All help is appreciated.
John:confused:
Not sure how different your 2003 is, compared to my '95. There are 2 fuse boxes. The other one is located on the drivers side of the dash, hidden when the door is closed. Look near the upper door hinge for a removeable panel.
As I recall, there is a special, fancy fuse, in the under hood fuse box for the trailer lights. The location is marked on the underside of the fuse box cover.
Thanks
Thank you for the quick response:D I appreciate it.
I have been out there for the last hour and a half, finally got it figured out. The 4 pin to 7 pin converter was somehow bad... I had another one I had bought a year back or so, and now everything is good.
Thanks
John:)
Yes, there's another fuse under the hood in the engine compartment for trailer lights. I fought this for some time and finally found it in the engine compartment. It's one of them high speed, low drag fancy fuses.
Loren
