Dean Upson showed me his dealer installed 7 pin trailer plug that was mounted in his bed and gave me the part# for the harness. The part# is 82207253, and boy is it ever easy to install. It comes with a flat 4 pin plug like the one that comes on a trailer, so all that you have to do is get a 60" lead with a flat plug on each end to run between the existing flat plug and the one on the new harness and Viola! you have made the brake/turn signal, parking light, and ground connections. Then all that is left to do is run the power lead up to the battery, the brake lead up to the trailer brake connector and tap into the back up light for the center pin. That is all there is to it. the only hard part was working under the dash connecting the wire for the trailer brakes. The only thing needed besides the most basic of hand tools was a 2" hole saw and a drill. It was a very quick and neat way to install a 7 pin connector in the bed of the '03s. Thanks Dean and thanks to his favorite mechanic Dan.
Fireman
Fireman
