2nd Gen Non-Engine/Transmission trailer plug
Does anyone know the best place to get a metal trailer plug like t he dodge one that came factory. My wires were all cut up when the previous owner took out the brake controller. I am not sure how to wire it back up and am not looking forward to spending the money to have anyone else do it.
wire up ?
If the truck originally came with the tow package ,there should be a plug next to the steering column that should still be in place . If you do not have a plug then you could get a complete harness from a trailer supply co. That would include the wire ,braker , plug brake controller wire ,rear lights, and plug in setup for trailer or boat seven pin and or flat four pin . You can do it yourself just fallow the easy to fallow instructions and ask for help if you get in bind. Ron Bissett in Metro Louisville Ky
actually i believe there is just a single wire under the das that is either blue or green that is for the brake controler, the other wires needed are power and ground and a tap to the brake light... . easy stuff the newer ones are the ones with a harness, the older just have some wires
