Trailer spring bolts
Camper Down! I need help
custom hauling
Anybody know were i can get spring shackle bolts
that are drilled an tapped for grease fitting?
or do i have to do it myself?
Those plastic bushings are a joke. Got to be something better.
THANKS Frank
Frank-----If you have Dexter axels, they have a upgrade kit, about $120. 00. I did mine about a year ago. You get all new bolts with zerks ,nuts, links and equalizer links. The links are about twice as heavy(thick) as originals. It's the only way to fly. You will have 10 zerks to grease when completed. If you need some hints use my email address.
Thanks for the replies guys, I went to the Dexter site
and didn,t see anything. I,ll give them a call.
I took it all apart last year and greased everything
and the plastic bushings still wore out.
I think i. ll go with the up grade.
Thanks Royal, I,ve had this thing apart a couple
of times, getting the height to match the truck.
Thanks again
Frank GLTDR
Re: Shackle bolts
Frank----I forgot to add that the kit has good bronse/brass bushings that replace those worthless plastic ones.
Thanks guys
I just ordered the kit, I did not know about the equalizer
numbers. Keep my fingers crossed.
Thanks again for the replies
Frank
