Trailer tires E to F range
Never Lube Bearings
any helpful advice on installin b&w turnover ball
lorirobert
Need to buy new tires for camper. We have a 30ft. SunnyBrook 5th wheel that weighs in at 12K loaded. The Wranglers LT are only 4 years old , but we had two tire issues last summer. My tire dealer says that it is recommend to change your tires every 4 to 5 years reguard less of wear. I was thinking of going to an F range tire if it would work out. Most of our trips are long runs, and i am always keeping a check on tire pressures before we head out. Any input would be appreciated. Thanks Robert
I know there will be some disagreement but I have had excellent luck with Hankook F rated tires on my 4-horse trailer with living quarters which is in your weight range
IF you run over 65mph you should use a good LT truck tire. Trailer tires is only good if you do not run over 65MPH You can look this up for your self. ===Good Luck I run fire stones LT Transforce on my fifth wheel 3 years old look new. Had goodyears trailers tires had 4 blow out in 4. 000 miles! Had to repair trailer 2 times. Goodyear ask what speed I ran on the interstate roads. I said the speed limit. they said sorry no tires for me.
I'm running BFG Commercial LT215/85-16 E on my 11200 gvwr 5er. Their '03 dot code dated and with 48k miles they should last another couple of years. My 18' implement trailer has the same BFG Commercial in LT235/85-16 E and are '00 dot code date.
As other poster says the Firestone Transforce H/T LT makes a good trailer tire.
The best 16" tire for trailer use is the all steel ply carcass Michelin XPS Rib LT E Michelin recommends it for commercial trailer use. The Bridgestone Duravis R-250 is another all steel ply carcass and is gaining in popularity with commercial haulers on their trailers.
Uniroyal Laredo HD-H LT 16" E came out on HH II 5th wheels.
The Goodyear Wrangler's were problmatic when used on trailers several years ago but Goodyear supossedly fixed its problems.
The best 16" tire for trailer use is the all steel ply carcass Michelin XPS Rib LT E. Michelin recommends it for commercial trailer use. The Bridgestone Duravis R-250 is another all steel ply carcass and is gaining in popularity with commercial haulers on their trailers.
I totally agree that the LT 235/85/16, LR E, Michelin XPS Rib is the best tire you can put on your 5er. They're a little spendy, but well worth the money.
