Trailer wheel width ?
Aero drag reduction
Cequent Plans Layoffs in Tekonsha
My son is going to put XPS ribs on his trailer. The rims he has now wont work so buying new ones they come in 6 or 7 in width what would be better and why? Tires can go either
It did 6 or 7 inch can get rims in 6 or 7 in that is the question. They both have 0 offset so just wondering. The only thing that I could come up with would be difference in sidewall flex ???
What size XPS Rib are you going to be installing? This will matter a little bit. All else being equal, I would do this: For the LT215/85R16 and the LT235/85R16 I would go with the 6 inch. For the LT245/76R16 I would use the 7 inch.
But if fender clearance is tight, go with the 6 inch. The wider wheel will make the actual, exposed tire profile a wee bit wider.
If the trailer will be used on nasty, ugly gravel roads, I would go with the 6 inch wheels. Having said that, I use LT245/75R16E XPS Rib tires on wheels from a 1996 Dodge CDT 2500 on a trailer used on nasty mining roads. They are, I think, 7 inches wide. I've never had a problem.
