Train Horn Project
A real CTD fan.
Suspension ungrade
Dear Friends,
I just complete the next addition to the Dodge After doing a month of research on the internet I decided I wanted to add a Nathan P3 train horn. I picked this horn because I liked it’s deep sound, but more importantly it uses less air that most horns which is important since I don’t have a train load of compressed air.
The hard part was finding the right horn. I had to derail three trains before I found a Horn that I liked … ( just kidding )
Here is the list of part I used
1. Nathan P3 train horn
2. 400C ViAir 12volt Compressor
3. 5 gallon air tank
4. 175 pound pop off
5. ½ air line
6. ½ Solenoid valve
7. Pressure switch with relay
8. Painless wiring fuse block
Mounting the P3 turned out to be the easy part. I had a piece of scrap Aluminum channel that I bolted down to my Kayak rack. The P3 horn weights about 15 pounds so it needs a pretty solid place to bolt it down to.
I mounted the switches in the roof console, I decided to us different switches so I could find the switch I wanted in the dark. This is a really easy place to mount switches compared to putting them in the dash. Getting thru the firewall is the hardest part of the whole deal.
Wiring was way more complicated than I expected . I used 4 in 1 - 10 gauge underground wire to go from the battery to the tool boxes . In order to get lots of power to the tool box I used three of the ten gauge wires to and one for the negative plus a ground wire to the frame, I figure this is a lot of overkill, but overkill is what a Cummins is all about.
Then I used relay for fuse block, compressor and solenoid valve. I hid most of the wiring in an inch space under the plate the compressor is mounted too.
While I was wiring I wanted to add a inverter and it helped cover up the relays and help makes things look a little neater
The end result is once I turn on the compressor it takes 3 minutes to pump up the 5 gallon tank to 150 PSI.
And that give me about a 20 second blast, which does not sound like much but trust me it is plenty at this volume.
:-laf:-laf:-laf I get gitty just thinking about the DUMB A-- that cuts in front of you then has to stop in a hurry mine is good for about 1to 2 car lenghts yours should be good for 3or4 :-laf:-laf I made awoman pee her pants (literally) in a parking lotOo felt kinda bad not. Have Fun Randy
LOL!!
That's awesome. Joe, I wish I had that setup!
I have a compressor and . 5 gallon tank for my airbags. That's probably not near enough though huh?
Driving here in the Houston traffic this would come in handy, especially for the people that drive 50 mph in the left lane talking on a cell phone. .
If you want to have a little funOo. watch for somebody texing make sure they are in an outside lane I repeat make sure they are in an outside lane then wake thier a-- up:-laf just beware you never know where they will go but usally they go for the shoulder but I bet they do'nt do it again for a long time I actually did it to my daughter she was not happy:-laf but she told me she's will never tex again Randy
I would like to own a set up like that for running calls in our VFD. I love trains and train horns. I work beside a csx rail and even have my scanner programmed to their channel. Not to the point of being called a "railfan". I think it's more the diesel part of the trains I admire.
Joe, ask you local police what could happen if you cause a wreck from scaring the sheet out of someone. Just don't want you or anyone to sit in front of a jury.
Controls
:eek:
I forgot the picture of the switchs, I wish I thought to put them all at once a year ago when I wired lights in, but never figure I have a need for any more at that time.
As for being legal, I am pretty sure they are not... . And I would not want to cause a accident just trying to scare someone or out of road rage. So no random blasting for me.
The nice thing is you can get someone attention with a short toot and you do not have to blast with full power all the time. Since you sound different than anything else on the road it easy to figure out where the noise is coming from
Joe
