MMeier said:My 03 calls for ATF. IIRC it takes just less then 4 qts. , anyone else? Just make sure you undo the fill plug first before draining and fill till it comes back out.
Tony T. said:I may be wrong here on the amount, but I believe it's just under 2 qts for the fill on the transfer case. I'm sure thats all I used when I done mine back last summer, used ATF+4. Also I used a hand pump that screwed onto the qt bottle,I got it at a NAPA auto parts for less than 5 bucks and worked great.
Tony
