trans bearing preload shimms getrag
Will Smoke Screw Make Truck Run Hot
Radiator Brackets
I rebuilt my trans a few months ago & I just used the shimms that were in there Im getting a rattle at low rpms in all but 4th which is loose main & mabey countershaft bearings
the place I bought the input shaft,countershaft, bearings & synchros from cant get the shimms they say they di what I did reuse whats there & the dealer cant either
there is a trans & diff shop in asheville 16 miles away but I dont want to go there & pull the rear cover off the trans there to match them up from their
wall O shimms
do any of you know who might have these main & countershaft bearing preload shimms? so I can just have them here & do it in a more comfortable environment than a parking lot in asheville?
thanks
JAK:)
use rear end shims
I found some of my rear end shims to be very close on id and od.
if its making noise start taking out the thinest shim first and check preload with dial indecator or by feel... should not bind and should turn by hand... i've done one and will do another shortly
good luck
jak
I apriciate you taking the time to answer
I have to corect you though you add shimms to preload the bearings
on the old 435 NP you removed shimms from between the front plate/TO collar the case to tighten them also on the 435 the rear bearing was a ball bearing so you dident want to preload the front tapered bearing that much
on the getrag the shimms are between the races & the rear plate so adding them tightens them & they are all tapered bearings so you can get them pretty tight
you would be suprised how tight you can get tapered roller bearings & get long life theres a spec for saab pinion bearing preload where you wrap a rope around the 5 inch pinion housing with the gear in a vise & pull the rope with a scale & it should take 10 lbs of pull to unwrap it now thats some preload:--)
on tractor trailor wheel bearings you run the nuts down with an impact to preload them
sorry to come on & start arguing
but I just wanted the info to be more corect
take care
JAK
Yes, I've been wondering about this. I'm going to need some, too. My friend had a machinist make some for him last time he did a Getrag. I may do the same thing if they aren't readily available... Anybody tried Standard Transmissions?
Andy
jak
the thing to do is go to a truck trans & diff rebuilder when you have the trans apart & match them up from their
wall O shimms get an assortment of thin & thick onesfor both the countershaft & mainshaft
mine fealt ok to beginn with but loostened up after a lil while so Id say set them a lil on the tight side so you feel some resistance = a couple foot lbs +-
rotational resistance
Ill look into standard trans though & get back to the thread
JAK
