Trans-Cool Manual Transmission Coolers
trans-cool from Geno's catalog #50
Interesting Oil Filter Leak
JWMiller
Can anyone rate or provide information on how well the Trans-Cool manual transmission coolers, Geno's Garage sells for the G56 six speed, work?
I would like specifics on temperature difference (before and after) installation.
Do they cool it or just prolong the temperature? On a pull? On the down hill side? Highway speed?
I would go with them... somewhat similar to FAST Coolers I had on my former 02 Ram 3500. They let you overfill a bit to keep that front bearing lubed on steep climbs and have more lube capacity.
Cheers, Ron
Ron,
Did the Fast coolers actually work or prolong the temp in the trans? I am looking at doing this with the Trans-cool or
if I could find a donor pickup with an auto, use an electric pump and put on all the stock trans cooler, lines, fittings and hoses to make it look factory.
Ron,
I beleive they did work...same concept as the aluminum rearend pumpkins. The only drawback was in Maryland when temps were in the teens, took a bit longer to warm up, but still shifted OK.
