Archived Trans cooler busted
Archived Torque Converter lock up issues
Archived Cannot remove the fuel filter 06
The fitting where the hot line coming out of the Trans cconnects to the small Trans cooler on the side of the block has cracked. Can I bypass this small cooler temporarily? It's not the threaded joint, it's the welded joint on the cooler. Any help or suggestions would be greatly appreciated
It can be bypassed if you can find all the fittings. Removing the fender liner will help a little for gaining access
