Trans Drain Plug Install
Smog Check
Last year for CA pre-smog 5.9L ?
I would put it as far back as you can because usually the truck is jacked up in the front to service the trans....That is unless you have a car hoist.
Passenger side of pan about 2/3 of the way back from the front on the pan, bottom 1/3 of the pan. Keep the hole between the pan rail bolts so you can get to them with a socket.
