Engine/Transmission (1994 - 1998) Trans fluid change
Engine/Transmission (1998.5 - 2002) dash brake light stays on
Engine/Transmission (1994 - 1998) Steering wheel tug while turning
New ceramic button clutch goin in friday, prob gonna change the fluid. I'm thinkin' about goin with Royal Purple. Not sure if I need to use the RP synchromax manual trans fluid or the RP Maxgear high performance gear oil 75-90. Also need to know how much it will take. If there are other suggestions I'm open to them. Thanks guys
Don't know which one would be better but make sure what ever you use is rated GL-4.
I had mine nv4500 fluid changed for the first time last year with Amsoil.
The only oils that are compatable with the NV4500 that I am aware of are Syntorque and Amsoil GL-4 product code MTG-01. Both cost about the same.
edit: 4 quarts
