The last time the trans fluid was changed, the shop used a cork gasket. It leaked bad. I replaced the cork gasket with RTV, now it leaks. I tried to add a little more RTV to the leaking area and it made the problem worse. Is there a non-porous gasket available for the 47RH? Maybe from the dealer?
If one does not exist, do you have any suggestions or ideas? Maybe I did something incorrectly with the RTV?
Thanks,
Aaron
Thanks,
Aaron
