Not in Direct [3rd] gear
You have around 1200 or so RPM available in OD, but not in direct or third gear. Manually select OD off, and you will find that you are at around 27-2800 rpm in third gear, pretty close to redline.
This is why the trans won't downshift. It should downshift to third if you are at around 65mph.
Greg L. the Noise Nazi
